issues with multiple CELS
MarsaGSX
488
29
Feb 15, 2004
Czech republic,, Europe
hey,
Here is my problem.
Went on local road on full gas:cool: (curves)
And lost my External dumb for wastegate..(didn´t know that)so all the exhaust gasses off the WG went directly onto Alternator...
When was on the end of this nice road my Cels starts blink (Charging,Hand brake-they shine very low...and on MPH side starts blink one Cel which don´t know..Check pics..its next the open door Cel
Can anyone tell me what this Cel means???THX
Used AIR press to clean it a bit..
And thought my alternator dies..used multimeter and checked charging threw idle on warm engine..going on 12.8Volts..when touch gas pedal jumps at like 14.4Volts...So looks like ALT. is working..
But what means those CELS????Sometimes that 3Cels shut off..and after second or so again blinks...or shine pretty low..then shine high...
(my Check engine Cel didn´t blink!)
Thanks for input
Venca
That one might be your battery light. This usually comes on when the battery isn't charging due to alternator issue. Have you checked the wires around the alternator? All those looms could be melted, which would be a very bad problem.
Fixed:thumb:
my wastegate dump cracks out..and all the exhaust gases blown onto/inside my Alternator... that heat burned piece of plastic inside...and smoke out material of the "diod wires"(Iam sorry..can´t translate..:coy: ) I just resolder those 3 wires and was done..
Venca
    • Detail
    • dsmmario
    • Canadian_CD9A
    • my98gsx
