Need some help ordering my DSM LINK!!
hippy
322
Jan 18, 2004
chtown,
Its a 98 gsx 5 spd it has teh following my mods i neeed ## guys help in ordring dsm link
It has a 255 pump
650 or 660 injectors (im not sure what the yare or the brand name teh yhave a litttle green on them)
Scm61 trim turbo
6 botl swap
3" gm maf transulatour
hks ss bov
4" intake pipe kn filter
fmic
afpr
i guess thats pretty much it
Now since idont know what the the injectors are is the going to make a big difference?? Im pretty sure teh yare 650"s they are black with a little green on them! ANd what a bout stock settings on the chip a default or something what do i do or get put there?? Thansk you very much!
Get it set up for the 660's. It is better to run a little rich than run a little lean on startup. Although, that much probably won't make a whole lot of difference. All the initial settings are for is the first start up. And you don't even need that. The motor does not need to be started to change anything. You can change the injector size, MAS, or anything very easily. So don't worry.:D
Ok so get the chip made for the 660's! Right on guys thansk alot!!!:thumb:
you may want to get inverted CAS too. Just one less thing you have to change when you take the batt out.
What does invert cas mean?? im assuming it has something to do with the 6 bolt cam sensor and the 7 bolt cam and crank sensor i did the 6 bolt swap my self and changed over the 7 bolt cam and crank sensor to teh 6 bolt cam sensor liek it says to on all the sites! SO what advantage is this invert cas?? Please tell me thanks!:thumb:
dsm-onster said:
You can't order DSMLink with with the invert cas option set as a default...
Incorrect :notgood: . Probably not an option for the 1g model but it is an option for 2g's.
Your thinking backwards, setting it for a larger injector will reduce the global setting, giving less fuel, making the car run leaner.
Like has been said these are the initial settings only & can be changed to whatever you want, via your laptop (or palm). It is a good idea to have the defaults set to your setup because if your battery dies it will revert to the origional settings. Not a problem if you have your laptop in the car to change them but if you don't you will have to run the car with those settings till you can get it.
Well show me the link where you can select invert cas as a default option when you order it? I just checked DSMLink.com and acted like i was going to order a 2g setup and nope nothing about getting the invert cas as a default... you can invert the cas in the system when you get it in the mail but you can't have it already inverted when you plug it in for the first time or when your batter is disconnected/dies.:notgood:
http://www.dsmlink.com/ordering-eprom.html
Not sure where you checked, go down to the bottom where the options are. Now look right after the rev limit & right before the MAF option, says CAS, then there is a check box if you want it inverted.
Maybe I'm wrong, I only ordered my dsmlink with the invert CAS option ROFL
Well I'll be a monkey's uncle! My badness. I clicked on the 1g order page even though i went to go check the 2g order page. Must be a force of habit. Before i got myt dsmlink, i would click on the 1g order page and dream of clicking submit:cry: . . .
so after i order it tonight cant wait all excited been waiting since last summer LOL I will order it with the invert option, will i have to change any of the wires outside of the car like the cas and crank angle sensor wire tell me more about this
Thank you very much!
Don't quote me on this but Im not sure if you need the invert CAS option as you have a 6bolt, isn't their CAS the same as the 95-96? I thought this was only needed when swapping a 95 ecu into a 97-99. You will have to change the spark plug firing order, swap wires 1 with 2 & 3 with 4.
