need some help on determining tire ware
zrk666
144
May 13, 2004
louisville, Kentucky
i bought my gsx from someone and it came with kyb gr-2 shocks and h and r springs.
as far as i know there are no cambe kits on it and when i changed the brke pads i didnt notice em if there were any. so my problem is, i am trying to determine wether i need a front camber kit or a rear kit because the tires are worn on the inside of every tire. the backs kinda look like they are pointing in twords the frame but i am not good at eyein it.
and if i do need a rear kit or a front kit please recomend some.
With your tire issue, you said they are pointing 'in.' What do you mean by 'in?' Is it the front of the tire pointing in, is it the rear of the tire pointing in? If its one of those, then you have a toe issue, which is adjustable with the factory control arms and tie rod ends.
If the top of the tire is pointed in, which i'm assuming, then you have a negative camber issue. This will cause excessive tire wear on the inside of the tire. Being lowered this is more than likely your problem. Get it on an alignement rack if you are not sure. A good alignment tech will be able to tell you whats wrong and how to adjust it. Look at spending about $90 to get on the rack.
