need some 420a help.
JMiller
684
Jun 30, 2007
Irmo, South Carolina
Ok i have a 97 RS that has been sitting for a few years and i am about 80% done putting it back together, but a few things are slowing me down. Any help would be great, Thanks.
#1 What connects to this, and what is it?:confused:
#2 I'm blocking off the egr, so do i need this?
#3 My water temp sensor fell apart:( can i buy a new one at auto store.
1. Cruise control, fuel pressure regulator, and the EGR system depending on what you have... 95+ cars won't have a vacuum referenced fuel pressure regulator and cruise control was obviously an option.
2. No.
3. Yes.
I've been looking all day for some hidden hoses near the firewall and haven't found anything. Where exactly is the FPR on this motor, and once again since i'm removing the EGR would i block off one of small lines(circled in blue)?
Not sure it this will help solve the #1 but its a 97 RS with ZERO options.
Well, then one of those ports probably connected to the EGR system, and the rest were probably blocked off. It's perfectly okay to block them all off if you're removing the EGR system. Your local auto parts store should sell rubber caps for just such a purpose.
