Need Serious Help Pointed in the right direction spec and Tech
Mobile174
Jun 29, 2008
Pomona, California
ok heres the history of my car. I have a 98 eclipse RS this is my sec time rebuilding my engine:cry:. My main Goal is to make my car a sprint I need the quick acceleration and the top speed or at least get my car to do 180mph or more. So I need advice with some performance parts that I'm gonna buy
list: Engine
JE pistons 10.1
JE Piston Ring
Crower Rods
Federal Mogul Rod Bearing
Federal Mogul Main Bearing
Cometic head gasket
Crower valve train
Crower camshaft
Crower Valve Spring
PEP Stainless Steel Valve
BLE Solid Lifter
SBI Rocker Arm
SBI Valve Guide
SBI Valve Lock
Melling Oil Pump
Cusco Oil Catch Can
Thinking of buying Hans turbo kit or Star turbo kit or just build my own ?
Greddy blow off type R
Nitrous Express N-Tercooler just for looks :cool:
Don't know what kind of intake manifold to buy OBX or Venom ?
Don't Know what type of Fuel Rail is Better OBX, AEM, Venom ?
Uhm for The Fuel Pump I guess Walbro 255l if that a good one ?
Do I need a fuel Fuel Pressure Regulator ? and what type ?
Venom Stage 1 Fuel Injector
List : Cooling
Proform Universal Slim Line
Mishimoto Radiator
Airtex Water Pump
B&M Universal Hi-Tek Oil Cooler
Sard Breather Tank
List: Drive train
Spec stage 3+ clutch kit
Fidanza Racing Axles
Symborski Solid Shifter Plate Bushings
Don't Know If I should Get an Quafie LSD ?
List: Muffler
Apexi N1 Muffler
List: Ignition
MSD Coil Pack
Bosh Platinum spark plugs
Nology Hot Wires
List: Stoping Power :cool:
Hawk Full Race Brake Pads
Brembo Brake Fluid
Brembo Sport Cross Drilled Rotors
or Should I just get the Brembo Big Brake Kit ? :cool:
list Suspension
I all ready have Shunk coil over kit it
Came with the car when I bought it or should I get
Megan Racing Coil Over Dampers ?
NRG strut bar
welp Thats all I can think of at the top of my head so is the part list good for my goal or should I get rid of a couple of parts or should I just get an 2.2 stroker kit? if so do I need to bore out the block or what do I do with the block ? compression test, bore, hone or what? hers a pic of what my car is gonna look like when I'm done
I also need help with my Ecu, I'm not gonna put back the air conditioning and the power sterning. Now the Ecu has an sensor for the power sterning and the air conditioning and the washer fluid ect. Basically I want my Ecu either reprogrammed so that when I put in my new engine the only thing that I wanna see pop up is the check engine light for something important I'm also doing some weight reduction in the engine bay I got rid of the air conditioning hoses to. I heard that technosquareinc.com, Megasquirt.com works on Ecu but do they delete some of the Ecu codes?
theirs a couple place out here in cali that have not hen but open road
Well, seems you have interesting goals.
I hope you have a lot of money! :thumb:
One thing I would be potentially careful about is whether or not you want to do all this work on a 420a car, if you have the money just get a 4g63!
:talon::dsm:
I hope you have a big wallet to do alll of this. 180mph or more?Wow.. Honestly dont waste your time with all of these parts on a RS including the turbo kit. Buying yourself a turbo car will put you closer to your goal financially unless once again you have a fat wallet.
The money is not the issue I just wanna know if the parts that I'm ordering is gonna make my car go that fast or what ? epically about the Ecu problem I'm having with
