Need Rim Help
JmacDaPlaya
39
May 11, 2004
Lacrosse, Wisconsin
I recently purchased a 97 gst spyder and it is completely stock. I picked up a set of TSW Rims with 225/50/18 yokohama tires on them. I tried putting them on my eclipse, but they rub. They barely make the front and the back they are rubbing very badly. What can I do to make these rims fit??? Any help is really appreciated!
Put washers between the rotor and wheel. Keep adding washers until you're clear, plus a little bit. Measure the stack of washers. Order the spacers.
We cannot do this for you over the interwebs.
Put washers between the rotor and wheel. Keep adding washers until you're clear, plus a little bit. Measure the stack of washers. ORDER SPACERS.
Fixed.
You may just have too "thick" of tire. I have 225/40ZR18's on mine. You may just need a thinner tire.
Um, thanks ... ?
Most people forget that last part..Just wanted to make it clear, to not use the washers and order spacers.I could see someone seeing the post and using the washers period..
  • Wanted 6 bolt NT water pipe
    • chrisman287
