need pressure plate bolt part #'s
jrpmp69
312
Nov 8, 2003
Las Vegas, Nevada
I was wondering if anyone has the Mitsu part numbers for the bolts that hold the pressure plate to the flywheel and also the bolts that hold the flywheel to the crank for a 2g eclipse GST.
Thanks.
Thanks.
7 bolt flywheel bolts are MD302074
4g63 pressure plate bolts are MD736249
Hope this helps :thumb:
I really like the pressure plate stud kit from fp. It came in the aluminum flywheel install kit, but you might be able to get them seperately. http://linux.forcedperformance.net/...Product_Code=FPFWkit&Category_Code=DSM-Engine
When I installed my 2600 pp, I had clearence problems between the stock bolt head and raised section of the pp. The only way to tighten them was with an extremely thin wall socket which I didnt have access to at the moment. Well, I found some hardened allen head bolts locally that worked really well untill I switched to a fidanza flywheel.
  • For sale 2g 2G DSM Link V3
    • frosh29
    • The_Partout_Spot
    • The_Partout_Spot
