need opinion on boost leak
teamitr
100
Jun 14, 2005
Riverside, California
I have about 4 to 5 small pencil led size holes on some welds in my charge pipe is that affecting me alot while at boost and also would it be the cause of my vac reading to be at 40.
pay 5 to 10 bucks and take it to any muffler shop and have them weld in the little holes. that can cuase alot of loss of performance.
well i have an electronical one so that why it's giving me that number i guess.
so what else culd be wrong?
Spooling99 said:
I thought normal was 18 at idle and around 24 on deceleration.
It depends on compression, cams and elevation. I see 16 at idle and 24 on deceleration with the stroker and Comp 200's.
For the original poster, if your gauge is electric and not mechanical, I would recommend that you either re-check the wiring or purchase a mechanical gauge to see what your true vacuum is.
Cheers,
Andy
But they go to 30in/hg... I'm saying I didn't know they made gauges that read all the way to 40.
Just one thing to point out, 30in/hg of vacuum is the most you can ever have, that is a perfect vacuum.
I figured when I read the post he was listing 40kpa, that would be typical with a few leaks. My car idles at 24kpa. ????
not if your talking kpa, if your talking inches of vacuum then yes. That is why I thought he must be talking kpa. I run speed density on my car so I am use to seeing the numbers in kpa format, so idle is at like 24kpa and WOT is 100kpa, and 10psi boost reads like 170kpa.
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale 2g 2G 7 Bolt Cylinder Head
    2G 7 Bolt Cylinder Head $250 + shipping & paypal fees* deck surface measured measured at 5.20...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
  • For sale 4G63 4G63 6 bolt -GM trans adapter plate
    4G63 to GM trans adapter plate. 350/400 turbo. 700r4. Gm manual bellhousings of same era. 6...
