need more safc help!!!!!
mudslinger4970
Mar 23, 2011
Fairbanks, Alaska
Okay so as i stated in my last post my fuel system stock, i have a 3" cat back, manifold, k&n with no airbox ETC. I installed an safc in my car because i got it for free and i thought it would be a cool gauge to have, i know i really don't need it until in upgraded my pump and injectors. so my question is what do i need to adjust on my safc to compensate for removing my lower honeycomb, people say it makes your car run lean. Is removing the lower honeycomb a good idea anyways? How does it help my car?
Removing the honey comb increases air flow bit heres a link to some basic settings on safcs. RRE's Super AFC Setting and Adjustment Tips
Also make sure the sensor type on the afc you selected is karmen our mafs are this type. As far as individual settings you will need at least a wideband to tell where your sitting at on afr.
I used there guide to set up my safc but with my cams It took me forever.
