Need little help
mickey
289
Aug 7, 2011
New Haven, Connecticut
I want to buy this fan but it say select the size. I have no idea which size i should get. It say 10 inches, 12 inches or 14 inches. I dont get it, I thought it only have one size to fit on the 420a radiator. I dont want to just pick the size and get mad when i receive the fan. Explain to me please. Proform Universal Slim Line Electric Fan
it is because they make that fan in different sizes to fit different cars. measure the diameter of the fan on your rad and then match it to an option given.
You could probably find an OEM one for around that price. That fan in the link wont pull nearly as much air as on OEM one.
The fan won't bolt on like the stock fans, it will have to be zip tied or something similar. So size doesn't matter, you would want to go as big as possible. But like 2GCruiser said, even two of the 14" fans won't flow as well as just one OEM fan. Since your NA you shouldn't have any problems fitting both stock sized fans in there.
If you do get fans, the description on the radiator you ordered is 13.75 inches by 26.625 inches.
so 14" fans would not fit, you should probably go with the 12" fans.
You could probably get the 14" to work but, the 12" would fit within the size of the radiator you posted.
