Need a little help!!!
VerySlowTalon
Nov 29, 2016
Puerto Rico, Puerto Rico
I was rebuilding my Talon Tsi 91 with a new transmission because i broke the oem one, and I THINK something is missing because i have front part in the air and the rear in the ground, i start the talon everything is fine the gear feels little tight but better than the first one, but i put 1gear and i was taking off the clutch waiting for the awd activate and its doesnt do anything just the the left axle was moving. Please need help i dont know if i forget something im new with tha awd system!!
Why would you try to active the awd system with only the front wheels off the ground? You do know you can really hurt yourself or broken the car and maybe its surroundings if it would have moved forward? Get all wheels off the ground, put it in 1st and move the wheels by hand. See if they move.
Are you sure your tcase is in good working order?
Well i put it back the same way i take out, or is a order to put it?
Idk man i was curious!! And the car doesnt move anything. But believe me the position of the car doesnt fall.
But let me ask the awd of the talon when I took of all the cluth need to activate? Or is like other car depends the rev?
okay so you have half the car on jack stands and put in in gear and attempt to drive forward?
are you trying to have the jacks slip and go through the floor?
I have my car half on jack's stands and the other half on dyna jacks Thats why you need to ask first buddy ;).
