2G Need injector help (misfire)
605jdm
169
15
Feb 7, 2016
siouxfalls, South Dakota
Got a misfire in cylinder 1 and pulled out my injectors and saw this. Is the right side cylinder 1? and could the different injector be the problem?
Yes it is if your looking at the front of the car. Just buy a new set of them. check plugs for cracks in ceramic. Mist water over and around wires have a buddy bump the key and look for jumping spark
I switched the injectors and it was the problem. Does anyone know where I can get a single 450 injector? I don't have enough for a set
There will be a vr4 or 2g somwhere in a junkyard youll be able to get one off of spray cleaner threw it tho. I would always go new unless your money is really tight
