Need info on 1ga under dash relay box
1fastcolt
97
20
Jun 27, 2011
Tucson, Arizona
Long story short I'm putting a 91 manual awd engine/chassis/under dash wiring harness and gauge cluster (along with the steering column) into my 86 Mighty Max truck. Making it more or less plug n play.
My question is, what is the box coming off the main fuse box under the dash? It only has relays in it. I found 1 post online somewhere that says its only for windows and anti theft but I would like to get this confirmed.
If it can be eliminated that would be great. Thanks much. I'll have follow up questions once this is sorted. Steve
The starter relay is the only thing that might require attention. The rest of the relays appear non-critical.
Vehicles with Theft-Alarm System (A/T)
looks like that is for anti theft also.. so might not be needed.. thanks much..
The diagrams were meant to show that the relay at C-35X would prevent the car from starting if it was removed. But it doesn’t look to be a big deal to bypass it in any case.
Just want to make sure that future searchers don’t find this thread and think they simply don’t need the relay at C-35X. :thumb:
