Need help
The fronts will work, the spring rate might be a bit off. The rear will be different. The length of the rear struts are different.
I'd check this myself. I heard a rumor years ago the only difference is the spring rates. U can put agx and pro kit on gs, get, gsx... Is it optimal on all three? Impossible. But do they bolt up? My money says they do!
why are u doing this? Help me give u better advice... What parts were on your gs that you are trying to migrate to the gsx? Stock parts or what?
I'm not quit e surebwhat parts they are they were on the gs when I bought it an gave the car a slammed kinda look and wantedbto give the gsx thevsame look the gs is currently stripped down any garage and iv been using it as a parts car but pretty much there not going to work then?
I would personally just buy some new agx front strut and eibach springs. Not too expensive and will give it a great ride. Good luck!
