Need help
Dsm304
142
Nov 17, 2011
Mission, Texas
My question is when rotating the engine by hand is it supposed to be hars then soft and soo? Also how do you bleed or fill lifters with oil I just got a cup of oil 10-30 and put them all in there I dont know if I did that right? Any help helps thanks!
it will be sofe then have pressure as it pulls and pushes air. and as for the lifters you cam put as much oil as wanted across them. turn it as you do it to really lube it if it is a first start up after a rebuild. and if you did just rebuild it.. put 2 cap fulls of oil down in each spark plug hole.
