need help with ......timing
hondamunchergsx
124
Oct 15, 2003
reisterstown, Maryland
how do i get the pistons to top dead center so i can fix my timing because after my head gasket change alot was thrown off ...and also how do i know that my cams are in the right place if someone could give me a briefe rundown on theese two things i would be greatly appriciated ...or if there is someone in the reisterstown owings mills or maybe even md area ...i need help my car has been siting to long please help
viva la dsm :talon: :thumb:
ok for your cam gears you will see two dowel pins they must be pointed to the top then line the gear marks on them they will be little marks on the gear. for the top dead center rotate the crank until the timing mark is lined up there is a new recall on how to do your timing belt research that and it will break it down for you step by step
