Need help with Front Mount Install Ideas....
carbonfire
175
Aug 23, 2004
Waterloo, Iowa
Ok I have this :
front mount intercooer.... well just the IC the pipes are not for my car.... anyway Anyone have any ideas how to get the piping to work out well on my car... I want to go something like this but pics would be helpful if you have similar IC's
Turbo, tight 90 to the right (drivers side) and than into the IC some how.... and than the Pass side is easy... same as every other kit... but I cant figure out how to get around the drivers side well... do you drill, cut, or just bend under... what is the easy way?
BTW I have a 91 TSI
oh I have a T3/T4 turbo.... but we got it figured out now... hahah... I should post pics of it, it looks bad arse
Yes, please do.
Maybe not the best thing, but, I have to remove my windshield washer bottle to make enough space. I am sure I could put it back on but I think I am just going to route some tubbing from the rear washer bottle, anyways, my piping goes from the turbo down to the bottom of the rad and heads straight towards the drivers side. Right around the alternator it starts bending downward just to clear the frame and then back up and around to the intercooler. Let me know if you need pics, I will have to go out and take some.
Laters
Tort9320g said:
what's that core flow, about 400cfm? OMG
You don't believe that IC will handle the garrett? a 50 trim flows 710 CFM, right?
The post originator will have to let us know how well it works. is it one of the eBay IC's? mark
That is the one from my Sunfire..... and Jason ran it on his Venger for a little while and he got madd fuel cut with it because it flowed soo well with his 20g.... he said 15psi with that IC was better than 20 with his old one!! I think it will work... we planned on running it with my GT28 Disco Potato... Should flow fine
:talon:
P.S> No it is not an E-Bay one... it is actually quite nice
And I think my Turbo is a 60 trim
