Need help with engine management...
fourreGsixty3
1,810
34
Feb 4, 2006
Essex, Connecticut
Ok, Its been a while since Ive posted a thread here. I know that I will be going with a DSMLink v. 2 for my engine management. I will also be using a 3" GM MAF, and an o2 wideband, not sure which one, so many choices, I am kind of leaning towards this one>>>http://www.slowboyracing.com/more.php?id=2274&. Ok, now for my real question. Can I wire the GM MAF and the o2 wideband up to a palm, so I can adjust them both from it, and use the DSMLink, I heard of one person doing this on here. Also is there any software that I would have to get to run DSMLink on a palm or can I just download it onto the palm? Also I know I have to get an EPROM ECU to run the DSMLink. Not sure if this makes any sense, but if anyone has a question, Ill try to clarify.
Thanks in advance,
Dustin
You can't make any changes to the wideband or MAF-T through a Palm. The MAF-T has dip switches inside the unit for you to make changes. The wideband can be connected to the stock ecu for datalogging purposes once you install Dsmlink. Dsmlink can be run from a palm and the software is available once you purchase Dsmlink.
Instead of going with the Gm MAF-T, I would just get a 2g or 3g maf sensor. They're much easier to tune with and the cost is significantly less.
