Need Help with engine harness
Other than the CAS, Throttle body, and Coil connections being different, why won't this swap work?
If he were to upgrade to a 91+ CAS, TB, Fuel rail, and Coil, is there any other reason the harness swap won't work, besides a factory tach issue and a two wire ECU pin swap?
