need help with coasting fc offset
95tsiawd0330
124
Feb 9, 2012
woodlyn, Pennsylvania
1.)does anyone know where i should set my coasting fc offset at.because when i let off throttle it goes in fuel cut to fast and when i push clutch in and let off the gas it goes to fuel cut right away.
2.)also when i am on the highway and i let off the gas pedal and leave it in gear about 5 seconds later i get a pop sound (like a back fire)and timming is set and 5 degs at idle with new gates belt.anyone know why?
It depends on your idle. revlimiters [ECMTuning - wiki]
My idle is 1100 and I have it set to 190. Sometimes that's a little too high depending on what your ISC sits at when idling with no load.
well i just found out what was happening i had my throttle tip in set to high causeing to much of a fuel squirt.:thumb: also i ohm my isc and got 48 ohms on all leads is that ok i hear that it should be around 40 ohms so is 48 ohms good.i had isc set at 30 on link and when the fans came on it would go to 37 then back down.now i drove the car around for 2 days now the lowest it will get is 76 on the isc is this ok?i have no boost leaks just had injectors bench tested by tom so i can dial in injectors.what do you think
No.
attachment.php
  • For sale 4G63 NEW Stop Tech Drilled And Slotted Rotors
    New Stop Tech Drilled & Slotted Rotors $70 + shipping and paypal fees* FITS * Eclipse GST...
  • For sale 2g 2G GSX/GST Manual Transmission Steel & Poly Mount
    2G GSX/GST Manual Transmission Mount (Steel & Poly) $45 + shipping and paypal feesYou must be...
    • sanmantsi72
    • El_marto
  • For sale 1G DSM 4G63 PARTS
    • The_Partout_Spot
