need help! what's the differences
Tinted1gTurbo
Aug 17, 2009
Racine, Wisconsin
So I have a 93 eagle talon 2.0 N/T shell and I'm going to be putting in a 2.0 turbo engine in it and I was just wondering what the differences are that I have to worry about?
The mounts are completely different along with the wiring harness. Its kinda hard to do
Ok first the motor is in. ( dropped it in today) found out the motor mount for the trans. was different. second its a 6 bolt so maybe it isn't out of a 2g like I said I'm not that sure what it's out of. I'm using a 1g head so I know that will be fine but when i bought the block the guy said supposely it's out of a 2g so I don't know. Do you guys know is there anything else I should be aware of besides the stuff you've told me?
Well when I bought the car it was just thrown together and it had a turbo engine but a N/T tranny. So I ended up getting a parts car and taking the trans. So I thought it was different cause one was N/T and one was a turbo.
Post some pics of the bay and your motor.
As I've read it, the NT MAF may be retained for a NT > turbo conversion. It will not plug-in to a turbo harness. The plugs are different. The turbo MAF has another wire, to send the ecu a signal for the stock boost guage. That is the only difference, but it will work in a bunch of galants and other Mitsus
1g turbo ECU will make it alot easier as it will be almost plug n play, don't forget to wire in the knock sensor and injector resistor pack for the turbo injectors also.
