Need help spark question
I've never had the pins cause a no spark issue. Are you sure your cam sensor is good/ wired correctly? Are your injectors firing?
The wiring is correct and the and coils don't spark and the fuil rail gets gas so the only thing i have not done on the rre method is the pins thats why i ask if that would make a no start swap cause of the no spark.
It would have spark either way just the firing order would be different.I would think wiring/cas/ecu/igniter.
What cas are you running?Who did the wiring?Have you tried other coils or igniter?More info would help on what you have tried.
The wiring is the connecters from magnus so it should be good, cas come from working car, ecu is a 95 and it works, ignator woks.
So just wondering if not doing the ecu wiring cause the no spark and no start.
I have done many swaps and I have never had an issue of no spark from not swaping the two wires around.You can also do it at the coil pack plug,Just swap the 2 blues wires around and leave the firing order alone.But either way it would still have spark if you didn't.
One of the things I listed in my first reply has to be bad or maybe a stupid fuse or something.Thats all I can tell you .
What about the coil packs?Never heard anyting about them.
Got it to start today and did the ecu wiring swiching the pins of the injectors and know i have spark, yes whe need to do the ecu wiring like rre and magnus says to have spark. Dont skip that step doit right and the car will start at the firts try
:hellyeah:
:hellyeah:
I had to do the same for my 6 bolt, just didn't get to your post in time.
