1G need help question about coolant line
indiana91gsx
Jan 31, 2006
greensburg, Indiana
I am installing a bigger turbo and don't need the anti-freeze coolant connection for the turbo. Do i loop the in and out together with a hose or do i just cap them off.
If you are refering to the water pipe outlet for the stock turbo cooling, you can either block it off yes, of use a nonturbo 1g water pipe since it doesnt have the outlet there. Then cap the other. Hope that helps. Good luck man.
thanks, that is what i wanted to know. figured i could but wanted to make sure.
