Need help only boostin 1psi
Streetsweeper21
140
Jan 11, 2006
Atlana, Georgia
Hey watz up dsmers my friend car was runin fine than he put an aftermarket bov and it was okay until the weld came off now he put the stock back and its boostin 1psi been like this for 2 weeks now lil advice would be helpful thanks everything is stock accept he has a 16g and a safc
You problably have a boost leak somewhere in the system, and thats where you're losing your pressure.
IF it was running good, then you switched the bov and the weld blew..and you went back to the stocker..LOOK THERE. You only messed with one thing. Chances are 99.999999999999% Thats where your problem lies. Re-install the OEM one correctly, and take your time. Then boost leak test.
  • Wanted 2g Test Pipe/Straight Pipe
    Just wondering if anyone has a test pipe that replaces the stock cat for sale. No preference for...
    • DankYeezy
  • Wanted 4G63 Ecu 1g 1991-1994 Eprom socketed
    Wtb Ecu 1g 1991-1994 Eprom socketed in good working condition!
    • niki_talon
  • For sale 4G63 Stainless T3 header w/38mm wastegate flange
    Same header you can get for $230 on eBay. Like new, only ran for 10min or so. Price is shipped...
    • GRNDSM
    • dsmmario
