need help! need a new motor?
boostfreak87
Jun 7, 2006
Huntington, West Virginia
hey i am looking at a 1st gen that i found around town. i stopped and asked about it and the guy said that it had low compression on #4 and that around 5500rpms it leaked oil. was just wondering if anyone had any idea as to what the problem might be and how much it would cost to fix it. thanks
If it's losing oil at 5500 rpms, then it's likely the head gasket or a warped or uneven head. It will blow air out of the side and by an oil channel and cause the oil to push out. This would also cause the low compression.
My money would be on a warped or uneven head, as it would lift the one side up slightly, possibly causing only on one cylinder on the end to have bad compression.
Swapping out the head gasket and getting the head resurfaced would likely cost around $400 at most, and this is on the high side. You could also get a used head to swap in if the head is too warped for a basic resurface for around $100.
  • For sale 4G63 Race parts.
    It is the time to make room to improve the DSM, getting rid of some extra parts I no longer...
    • GST2012GSX
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
