need help missing harness and hose.
99 gst spyder
522
Jul 12, 2007
st. paul, Minnesota
here's the vacuum hose leading on the top of the cruise control and ends somewhere behind the intake manifold, and the harness here. it's not connected to anything and was wondering if it should.
my knock sensor only hase one red wire from knock sensor to harness. the harness is a two prung for two wires, the first prung is the red wire, the second prung is a small black wire that's cut and soder about an inch long. helps please. i'm not reading any knock on ecmlink at wot, is there something wrong.
what could be wrong if your timing belt is off center to the motor side and starts rubbing on something and tearing off about 1cm? right after a new timing belt change.
thanks
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
  • For sale 2g Clean title
    • FirstTimeDSM
