Need help. How do I degree HKS cams in my 2.4
Turbogsxmitsu
40
Feb 22, 2003
ridley, Pennsylvania
Need help. How do I degree HKS cams in my 2.4, I have a degree wheel. Just need good instructions. Mods: G4CS built block, with 1G head. HKS 272,264 cams.
Looked at your profile and saw that you had adjustable sprockets, so you should be good to go...
did you even look at that site?
thats like saying, I have awd, how do I degree my cams. I know how to do it on fwd, but my car is awd......:toobad:
it doesn't matter that your car is a 2.4, if your degreeing for the center of the lobe, your degreeing for the center of the lobe. theres no displacement mentioned in any of that. JUST READ THAT SITE
LOOK were all not as intelligent as you are. I have HKS cams and I want to degree them specifically to my block(G4CS). I need the exact procedure. Every setup is different because of decking the block and plaining the head. Everyone also is not running HKS 272, 264. If you can help, just help. thanks
