1G Need help finding best TPS and fuel pressure regulator
redd_the_1g
Mar 29, 2024
Newcastle, Wyoming
my 1g eclipse gs sputters pretty bad upon take off anyone have ideas? i was told it could be a tps because it also has a bit of an idle surge. also was told could be fuel pressure regulator. Any other ideas?
idle surge is more often caused by a post-MAF vacuum leak. on a NT you have much less piping but it's still possible you're allowing unmetered air in. check all your air intake hose clamps.
Then I'd adjust the idle position switch to make sure it's working off a closed butterfly and it's not opening your thottle plate any. An idle position switch that opens the throttle plate allows more air in than it should, so your RPMs raise until it hits the cutoff point. Since your idle switch is reporting a closed throttle, the ECU cuts injectors, then RPM drops. RPM drops to the point where it needs to turn the injectors back on, and you're performing a loop. It doesn't much opening of the throttle plate to allow past a LOT more air.
The TPS you could adjust to read 1.5v at idle, it wouldn't change how it idled.
A malfunctioning FPR not allowing enough fuel in could theoretically raise the RPMs but I've run pretty damn lean at idle (16-18:1) on a deliberate mis-tune, and it never raised high enough to reach the cutoff or entered surge. Plus, it would run really, really rough.
