Need help finding a part number
99GSXAWDTURBO
218
May 16, 2005
Frankfort, Kentucky
I've looked on various OEM mail order sites for this part, and cant find it. Its the bolt that holds the "front" arm in on the rear suspension of a 2G AWD. There are 2 bolts that hold the arm in, the one that bolts into the frame, and the one that bolts in directly behind the brake rotor. I have found the one that bolts to the frame. I just need help finding the part number to the one behind the rotor. Any help is greatly appreciated. :dsm:
I'm assuming that you are talking about the rear lower control arm, and not the trailing arm. The bolt that you need is Mitsubishi part # MB844524, the nut is Mitsu part # MF430123 and the washer is MS450993.
If it's the trailing arm, (the very front one with one large round end, and an open 'U' on the other end), the part # is MB844521.
Contact JNZtuning.com They should have what you are looking for if you can't source it thru the dealership. Good luck!
