Need help finding a part number for the sensor in the thermostat housing
wcpierson
296
Sep 16, 2005
Cedar Knolls, New Jersey
I need the part number and name for the sensor in the thermostat housing that reads the coolant temp. Not the one for the fans or the one for the gauge on dashboard I need the 3rd one that sends the temperature reading to the ecu. It has 2 wires going into it.
This is for a 1g 6bolt'
Thanks
According to CAPS:
MD069879 - Water Temperature Sensor Unit
This is the part number for a 1991 Eclipse GS. Your Laser should use the same part, however, double check with the dealer.
FYI - I couldn't find 3 sensors located on the thermostat housing on the diagram in CAPS, only 2. The other one was for the gauge unit. The diagram for a 1G turbo engine had the same part number and also showed only 2 sensors on the thermostat housing.
Mike
    • george bromwell
    • pma1123
    • Sdcryan1
