twicks69
Supporting Vendor
- 4,335
- 2,076
- Mar 12, 2004
Milwaukee,
Wisconsin
I am running DSS Stage #5 axles that utilize a 3000GT rear wheel bearing/outer hub assembly (splined portion accomodates larger diameter/spline count outer CV cups), but am having troubles finding replacement entire wheel bearing/hub assemblies. I NEED the outer portion as a required piece. I can always cannibalize a set of 2G AWD rear wheel bearings for the inner portion. The bearing dimensions are the same.
I have only been able to find the bearing by itself; no inner or outer portion of the hub or the entire unit brand new.
I appreciate the help!
