need help fast! evo III turbo install
ZigsGSX97
113
Apr 30, 2004
Hickory Hills, Illinois
Ok i'm trying to install my turbo and i ran into a few problems......ok stock turbo is off and i'm trying to figure out how my new one goes. i have the oil braided line, so the oil lines are accounted for and are easy to deal with. BUT i pulled the 2 coolant lines off the stock turbo and they won't fit anywhere on my new turbo. Cuz the lines have a screw bracket on them and they don't line up anywhere on my turbo. in the pic at the bottom are two coolant hoses at the left of my turbo. do i just leave them hanging and not screwed or what? my new turbo has a bunch of screw holes in it but i don't even think i use most of them. also i got my turbo ported but my exhaust mani isn't ported and theres quite a difference in diameter of the two and they don't really match hole to hole. do i need to worry? thanks
You still should use them and hook them up. Just bend them to fit. You do not need to use the screw brackets. Be sure to look at how the coolant hoses are on the car to know how and where to bend them so they are in the right position to hook up properly. :thumb:
