need help converting 2g 95 gst fwd auto to 5spd
Status
Not open for further replies.
blackawd16g
Jun 4, 2004
riverside, Rhode Island
I have a 1995 GST auto matic i want to convert to a 5spd.was wondering if anyone has any info on this.i have almost all the stuff to do i.just need to know where to run the clutch line an some other things.an the easiet way to put is the clutch pedal in.anyone have any info on it an pics.would really appreciate it.thanks Justin
i need help on where to mount the clutch master cylinder an where to drill the hole on my 95 gst auto.also if anyone has any pics or info i would appreciate it.
There is tons of help available for this.
The master cylinder mounts in front of the drivers side firewall. If you climb under the dash and pull the carpet back you will find the three holes already stamped that need to be cut.
i cut the holes today they were really easy.didnt think it was that easy now im waiting for my clutch master an slave to come in.but im also wondering are there any differences between turbo an non turbo clutch pedals an brake or are they the same.i need the pedals everything else is simple just need to know about the pedals.
They are the same. Same goes for the shifter cables/shifter etc
Status
    • Sdcryan1
