Need Help! Battery/ Running
awdsm90
40
Dec 1, 2006
Sioux City, Iowa
Hi. i recently bought a 1ga 91 esi....yeah i know i used to have an awd 90gsx (reason for the name) but anyway's i was wondering if you all could answer a question? ok so i bought this car and it has a alot of new things on it, but my main concern is that it wont start properly the previous owner was putting in a new battery and he touched the hot to the motor and you need to jumpstart now to get going....is there something he might have fried? i know of a similar thing that happend to my gsx and it messed up the ECU? any help appreciated.:thumb: :talon: :dsm:
Check the black alernator fuse in the front fuse box.
It's a bolt in fuse, so you can just check for power on the legs where the bolts go thru.
You should also check all the other fuses in the other boxes, and at the battery.
thought id add that this 91 esi is red with black top and 5piece wing....mint 5spd new tan cloth interior...new alt,battery,trans,belts and tires....it was a steal had to buy it 900$ and it runs besides the battery problem:thumb:
