Need Base settings for n/a 4g63
Muzz66
Oct 21, 2008
Brisbane, Australia
I have just purchased a Neo and need some base settings to work with.The motor is stock (for now) apart from 2.5" system with hi flo cat.I am running 1g MAF but have a 2g which will be fitted soon after the battery is relocated and cold air box fabricated.
The base setting should be 0 since your talking about a stock engine.
Make sure your Neo is upgraded since until the past 30 days they had serious problems with Karmen MAF inputs.
How do I tell its been upgraded or not?Its running v 1.1.I am in Australia is the same problem here would you know?I have had no probs with it so far.If I use 0 as the base settings wont it just be running at factory settings?It is running rich.I have been unable to get my data logger to run and I am not sure if the ECU I have can be logged.Would you know how I can find out? Cheers Muzz
