Need advice on SAFC Neo settings
16gstingslikeaB
Nov 30, 2007
Henderson, Kentucky
I have a 96 TSI with a big 16g recently put on with 650 injectors and a 255 pump. I am still using my sidemount IC which is not in the best shape. I have 3" catback exhaust, racing clutch, big air filter, crushed 1g BOV, 8.5 wires and NGK 7's. I also have a new upper IC pipe. What should I set my SAFC to? It runs good on low end but at higher RPMS it seems that my car starts cutting out or losing boost. A lil help would be greatly appreciated!
Thanks, for the help! I am hitting a wall at 4500rpm though. It seems to shutdown and then blows out smoke. how do i fix that and what is causing it? Also sometimes when i first start the car and take off it seems to run like crap sometimes. I will push the gas in and it acts like it doesn't want to do anything, almost like its slipping. The temp is dropping in my area don't know if that has anything to do with it
