ECMlink need advice on my tune
jsawyer
Dec 20, 2008
westport, Oregon
hi there so i just recently got my car back in the road and am in need of some tuning advice. so i attatch and idle log and a short cruse log i was wondering how they looked. i also had a question about the cruse log at 147 seconds it goes into open loop and i dont know why i was cruseing at that point i got a random missfire code and my wideband blanked out i had to cycle the key off then on to get it to run right again
It seems like my wideband just randomly stops cycling but it seems to work fine in any other situation it only does that after cursing for a few minutes.
So I tested my o2 sensor and its working fine can anybody help me figure out why my car goes into open loop car is undrivable at this point
new idle log please give me some feedback
I'm willing to bet it has something to do with your TPS. Look at your TPS scale...165% Not to mention it is shakey in the moments leading up to open loop.
Turns out it was because I had the misfire dtc on but thanks for the help
:hmm: Are you running a 1g cas?
EDIT: nevermind, i see you're 6bolt. That doesn't really explain why you would be kicked out of closed loop:
http://ecmlink.com/wiki/fueltrimupdatepoints said:
2G Open loop mode (any one true)
Throttle position too high (varies by RPM)
Airflow too low (units are tricky, but it's very low)
Coolant temp < 51F
Coolant temp > 228F
The O2 sensor did not switch around 0.5v for over 128 seconds while running in closed loop mode. In that case, the ECU locks itself in open loop mode.
I don't see how a false positive misfire would cause you to go open loop.
Also, why is your intake temp and baro being locked?
  • Wanted 2g 2g Hood latch support
    On the hunt for the support that holds the hood latch assembly.
    • jesse12345
  • For sale 4G63 Hallman ES Boost Controller
    Boost controller
    • jpturbotalon
  • For sale 4G63 6 Bolt Kiggly Modded Oil Pump Pickup
    6 Bolt Kiggly Modded Oil Pump Pickup $95 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
  • For sale 2g NEW 2G OEM Timing Belt Tensioner Arm
    NEW 2G NEW 2G OEM Timing Belt Tensioner Arm $45 + shipping & paypal fees* these are $70 online...
