Need a little help with ECU!!!
hippy
322
Jan 18, 2004
chtown,
I have a 96 talon esi auto n/t and i need a ecu for it will the ecu out of the dodge neon work in the talon/eclipse?? I thought i read/ heard somewheres where it would work too?? ANyone know anything about this? Or know where i can get a ecu for a 96 talon auto??? Thanks!!
I'm not entirely sure about using an ECU from a neon, but check with the wreckers for a used one :talon:
The neon ECU will not work as far as I know. Also when looking for one, make sure you check to see if you have the "double ecu, its split in 2". The newer 96+ eclipses have the single ecu.
