Name this AN Rail Fitting
DSM90AWD
DSM Wiseman
2,921
112
Dec 22, 2002
Bear, Delaware
Just received this rail fitting from one of the vendors, but the mounting "slots" barely reach the mounting holes in the rail ('90). I specifically ordered the 1G outlet fitting, is this not what I got or is the 1990 rail different :confused:
I got one that looked identical to the one you pictured from a vendor out my way. I have a 1gb and it didn't fit either. I sent it back and bought the one that www.diamondstarmotorsport.com sells. It fit perfectly.
I only got 1 for the outlet side of the rail.
Can you do me a favor and measure the span between the two bolt holes on the rail outlet adaptor?
Thanks. Waiting for a callback from ExtremePSI to arrange the return and will be calling Nate.
Nice deal with the SpeedSource $32 for both sides (if they fit).
Not to postwhore :coy: but Niu at ExtremePSI responded that this fitting was apparently designed to fit both 1G and 2G rails. Guess the 1G fitment wasn't tested :rolleyes:
Anyway, he's sending me a free 1G-specific fitting (new design) Wed and told me to keep the one I have :thumb:
DSM90AWD I only got 1 for the outlet side of the rail
You might check the size of the one you have. It may very well fit the other end of the rail. :) I'm pretty sure the large one goes to the outlet and the smaller one goes to the inlet.
Tom
