Name that Turbo Game ( its a bullseye Housing)
RockSolidGST
151
Mar 23, 2005
Boston, Massachusetts
Ok here we go.
Kid says its a Bullseye 50 trim? Dosn't look like thre current model... So im not sure
http://www.slowboyracing.com/more.php?id=5466& ( 50 trim )
It looks more like the Bullseye M trim
http://www.slowboyracing.com/more.php?id=5675& ( M trim )
As of right now these are the only 2 pictures i have because the battery in my digi is dead and i can't find the damn charger. :thumb: But the Wastgate on it dosn't match EITHER of those turbos , so im lost. ill try to get more pictures up asap.
Its a 3inch inlet, its pretty beefy, Only OIL cooled , No water lines
I can pick it up for very cheap... Im an evo3 Right now , Suggestions?
Definately a Bullseye turbine housing w/ T04B compressor cover. More then likely a v-trim.
Thank you , Thats what i thought.... now just to find out what trim it is... The compress coevr dosn't look like there current models but i will try to get you guys pictures by tomorrow
Well im 90% Sure its a Bullseye V-trim , Anyone know the main diffrence between the 50trim and the v-trim , They are rated the same?
Warning about that specific turbo!
I looked at trading some parts for that turbo for a street car I have, and when I looked it over if you notice on the mating surface between the turbine housing and exhaust manifold, it has been ground down with a dremel type tool (Warped turbine housing, very common for thes housings). If you will also notice all of the crap down inside the bearing section, as there was nothing covering the oil inlet or oil outlet. You will also notice that there has been some obvious in and out play because there is a gouge on the compressor inlet where the wheel has scraped the housing all up.
Fair warning, that there is a VERY good possibility that the turbo is junk. I didn't risk it as I don't want to put it on a car just to find out that it was junk. He also says that the turbo only has 2500 miles, and with that much rust there is no way it has that kind of mileage. The kid selling it got it from someone else, who got it from someone else, and is still said to only have that mileage!.
Stay away from it!
