N/T Engine Coolant Drain Plug
Mattitude v1
250
Oct 20, 2003
City, Alaska
Just want to make sure, is this the drain plug on the cylinder block that must be removed to drain the engine coolant in a Non-Turbo? I'm not referring to the radiator plug, I know where that is. Took this pic directly beneath the suspected drain plug, it's circled and located above the oil filter.
