Dhan
Supporting Member
- 3,772
- 192
- Apr 29, 2010
Denver,
Colorado
Some quick background. I'm trying to troubleshoot my '91 Laser with a n/t 4G63 motor. I did a new head and lifters, plugs/wires, new fuel, and timing belts.
The car's got good compression, timing's right, fuel and spark is there. I start it, but it dies unless I give it throttle. So it won't idle at all. Seems to be running a bit rich too.
I've gotten DSMlink to connect with my n/t non-eprom ECU, using the factory system MUT-II. I have one log that I was trying to compare to others, but all other logs are from turbo models.
The O2 sensor looks off in my log, but I don't know how much it differs between the n/t and turbo. I'm in the process of searching the shop manual to see how to check if the O2 sensor is bad.
Does anyone else see anything of interest?
