ECMlink Please Help Dsmlink log
crazyquik22023
641
6
Sep 14, 2008
Akron, Ohio
Ok so my car runs badly.. can't idle w/o me giving it gas. also i think there is something wrong with my MAF. Here is a log with the car off
. the maf is getting some kind of reading at 14 hz but here is the log with the car running
the maf does not get any kind of reading. Does anybody know why this would be??? also could this cause my AFR to be 0:1??? thanks
Since you have intake temperature it seems like the MAF harness is probably connected OK. And since the only thing missing is MAF frequency, I'm going to guess that you removed an AFC when you installed the new ECMLink ECU and may not have re-connected the MAF wire that had been cut when the AFC was installed.
Am I at all close?
Thomas Dorris
Am I at all close?
Thomas Dorris
Yes you are correct I did remove and AFC but i checked the wire to make sure it was connected.. i will check again though:pray:
Am I at all close?
Thomas Dorris
damn i guess i didnt check them good enough the wire was disconnected. thanks alot Tom i appreciate it.
