ECMlink DSMLink log/ Tuning help
projekt1
436
Nov 21, 2006
NorCal, California
NooBe to link, just took my first log. Still not too sure on what I'm doing but I think there might be a lot of things wrong. What can you guys tell me from my first log? I want to know everything that i can do to make her run near perfect.
My profile is up to date.
I really can't help too much as your not even up to operating temp.
I would tell you your front o2 is cycling correctly, but that due to only getting to 145 degrees.
your fuel trims are off, try to get your combinedft to -/+5%. You will need to mess with your 600hz slider. But don't do this until you get a log at operating temp.
Jump on the link wiki and start reading, once your done....read it again.
setup your idle/cruise fuel trims
dial in your maf
start to adjust to your desired a/f ratio
start upping timing/boost
I can tell you that your tps doesn't need to be adjusted.
You can't tell if the ltfts are within 5% of zero because at 145* operating temp they haven't been updated yet. Coolant temp should be around 175 before they update.
Thanks for the input so far.
Okay, I will go warm her up then take another idle log maybe a cruise. Not sure about the cruise either because after putting the MAF and 550's back on, the warm up (the log above) sounded kind of funny:confused:.Just put a new clutch kit so no launching either:(.
New idle and cruise logs...
Please advise :)coy:Nu B)
