My water/meth results +29.13whp +33.69tq
ed_GST
233
3
Jun 22, 2008
Gurnee, Illinois
Recently bought a CoolingMist Standard Trunk Mount Kit
Today i had the chance and went to the dyno
Here some pics of the kit installed
The results:
Before and After
Im using a 50/50 mix
Had some problems with the wideband so im not sure of the actual afr
They should be in the middle 11's
Tuned with reflash
Clutch couldn't handle street abuse
So won't test it in the track until clutch kit arrives
I used a 500cc nozzle
Run #1 is without water/meth
Run #2 is with water/meth but no tuning was donde
The rest of the runs is just leaning the AFR a bit and adding more timing
I manage to add 3-4 degrees of timing
Boost was the same from run #1 to #6 in the last run gave it 3/4 turn to the MBC
Boost spiked to 24 and then went down to 22
Thanks for the comments!
