v8s_are_slow
- 2,825
- 280
- Sep 30, 2002
Panama City,
Florida
I'm always hearing about people who say they have fast cars but when they go to the track, their times suck cause they bog the launch with their stutterbox. I had the problem too and I use to launch better without it. But got to thinking about why I was having the problem and thought about how to fix the problem.
Problem for most- Gas to the floor and then bogs the launch. Every person I talk to say they hold the gas to the floor. Problem I was having was that I couldn't tell how fast I needed to let off the clutch. Kinda like when you're driving a car and you can tell how fast you need to press in on the gas and out on the clutch as you're feeling it engage. But it's more difficult to do that when the gas is to the floor right?
Simple solution- Wherever your stutterbox range is set at, just press the gas down until the needle hits that rpm and then stop. You still get the stutterbox function, still build boost off the line, and when you let off the clutch, you can still press in on the gas so that you can better judge how fast you need to let out on the clutch. This is what I'm doing and I've been killing guys outta the hole. Even the awd guys and I'm fwd on slicks launching at 5k rpm.
Went racing this past Friday night and killed every single person outta the hole. Sorry, couldn't give you a 60ft cause the tree was messed up so they were flagging us "Pinks" style. Anyway, hope this helps for anyone who's having a problem trying to launch with a stutterbox.
sneaky
