My stock 0-60
Talon-96
Banned Member
78
Aug 5, 2006
Hoquiam, Washington
Ok my 0-60 time is 6.34 after many tests, Its completely stock with just a open filter and the bcs free mod (did not help). Ok so 11psi Is stock I want to turn it up to 14-15 will these mods allow me to do so I got them now.
Boost Gauge
MBC
BOV
I/C hard piping
3" downpipe (delets cat)
Hard intake
Also I want to know What kind of hp with these mods at 14psi would be isnt stock whp 180?
You should be safe at 14PSI, but why not grab a logger so you can see whats going on. They maybe you can squeeze 16 safly. Whats your goals for the car ?
im gonna do the stage 1 on this site so hopefully 300whp, i know i got some work to do. Can you help me out with this logger thing im kinda confused what it is where it hooks to and how you use it?
It can be a Palm device with a cable to connect to your OBDII port, and the software to read what the ECU is doing. Check the classifieds, you should be able to find one for about $120 or so.
The OBDII is under the steering column, and you can use the logger to see your fuel trims, CEL ("check engine" light) codes, water temp, and a bunch of other things for maintenance and tuning.
cool thanks, you cant actually tune with that though can you? So i was planning on eventually getting the Apexi S-afc neo fuel conttrolloer and some sort of FPR what else would i need to tune?
Your also going to need a fuel pump like a walbro 255 and a set of injectors(550s or 660s).
The logger merely lets you moniter whats going on in your engine. The safc neo is a actual tuning device. That lets you change air and fuel ratio's. I suggest a better fuel pump before a FPR. Now the safc can only tune up for 650's and even that its eratic. So 660's are too big. The best place to start is fuel. With fuel you can turn your boost up, but a logger is definitly the BEST first purchase people can make.
Actually i have a set o 720s on my car, i tune with an afc and i also have a gm maf setup. I have the afc compleatly leaned out and it runs great. So you can run up to 720s with an afc.
Im sure the gm maf setup helps, but as far as talon 96s question i would probably stick with a good set of 550s.
well if you look under my wish list eldiabloz13 thats what i was planning on getting, thanks for the advice guys.
Do you have an E-PROM with a chip? If not, how much timing are you running?
