My Minor Rebuild...!!!!
BLINKY619
1,211
4
Feb 26, 2010
SAN DIEGO, California
Ok to start off i had just gotten a rebuilt motor. now along the way, my car kept skipping timing.... Would so it around 3 times a week...... Now i had taken it to 3 different dealers so they could tighten up my timing belt, well they would promise me it wouldnt do it again.. but it skipped 2 times with them.... so i bought every timing components brand new from the mitsubishi dealer and even bothered to buy 3 different hydraulic tensioners.... but it kept skipping.... so now the skipping belt was fixed but did enough damage to make my car not idle right...!! so after a few tests here and there i narrowed it down, coming to all the intake valves being bent. and my seals went out after a boost leak... so i went on and installed new intake valves with fresh valve stems and a good resurface...!!! i got the block and teared it down to pieces and started cleaning everything..... and when i took the pistons out i noticed that the ring lands stayed intact. when i took the crank out i noticed that it had scratches on the surface of all rod bearings.... so i went on and took it to get polished, after that i installed brand new clevite71 rod bearings.... along with a new piston ring set from the mitsubishi dealer.... also got the oem mitsubishi metal head gasket and every gasket i needed to use
So here i am sharing it with felow members here in dsmtuners....
So far ive installed the oil pan, oil return line, intakemanifold, timing belt, alternator, starter, head, reused my arp head studs
SORRY FOR THE CRAPPY PHOTOS.... CHEAP BOOST MOBILE PHONE
Keep up the good work. I'm in the middle of my complete rebuild and I don't envy you doing it in the car. I'm doing mine on the engine stand and work bench and it's got it's moments when even then i get a sore back leaning over.
Let us know how it goes as you get it back together.:thumb:
Well i didnt rebuild it with he block in the car.... ive tried it and its a mission.... i had the block out and hot tanked it.... followed by a good hone..!!!!
thanks people... so far its going good, i got a little more done today.... i got the turbo hooked up... also hooked up the other side of the return line to the turbo...!!! my power steering and my alternator, OFH, OIL COOLER, .... all i need to do to start it up is, to rewire my CAS and hook up my coil pack...!!!! and add some oil....!!!! well ill post more pics later and keep updating...!!!
