etay89
- 866
- 6
- Dec 27, 2009
Monroeville,
Pennsylvania
1-so my horn doesn't work. i try to press the horn and no sound. however, on my little remote, if i press the panic button, the horn honks. what's wrong here? i've tried checking the fuses, but they all look fine. any idea?
2-recently, i made a right turn and then my turn signal got stuck. now, the switch works 'fine'...meaning whenever i make a normal left or right hand turn and use the switch, it will go back to the center position. turning the switch to make my lights come on also work as well, but my right turn signal is just...stuck.
i tried to replace the switch. i found someone junking an avenger and thought it might work...yeah it didnt fit right. anyways, buying a new switch will probably fix my problem..but what if it doesn't? also, the hazard lights work fine.
