My GST ... few mods
defintally put the other two prothane mounts in. That was the best investment I ever did with my 2g GST. Also a 16g GST, is just down right fun. Very good street car, its a night and day differnce with a 16g. Also might think about a clutch a nice 2100 or something like that.
skip the AFC, save and get link, you will be much happier. Why spend 300 now, and then 500 later, when you can just buy it once. Besides, hold off till V3 comes out.. Its getting close FOR REAL this time, and looks amazing!:thumb:
10-16-2008 06:27 PM
sonik619 Quote:
Originally Posted by EvilutionaryTSi
Not to say that you need it now, but with it being fwd i would say that a diff would be helpful. so your puttin all power to the ground. i have a diff in the eclipse i have now and its a big difference then how my talon tsi was without one. also new plugs (stage colder) and wires (8.5mm, maybe)
Which diff are you using?
a qauife I think. The car was exactly like it is now, give or take a little, on my profile it says BM lsd. but i talked to the mechanic that put it in and he said it was a quaife. either way it makes such a difference
Well fixed the problem of the timing belt ... balance shaft was out of phase
also got a test pipe and street tuned the car
from 9.5 9.8 afr to 11.5, the difference is huge, the engine build revs a lot faster
also did the HD lip
:dsm:
I usually aim for 10.5 a/f, but Im a conservative haha. Clean ride, charge pipe, intercooler and turbo and you will have a whole new animal....
Last Update:
Dejon UICP and SS Tubular O2 housing
went to the track few months ago and the car ran 14.6
without the previously mentioned mods
Pics
O2 wrapped in Thermo Tec
Next in the list:
- better and wider tires
- e-cutout
- race gas tuned
hoping to get in he 13 sec with stock turbo
here is the last update:
- EVO III 16G is on its way (thanks jusmx141)
-EVO VIII shift knob is on its way
-Installed a Blox MBC (Hallman knock off)
-Installed EVO VIII wheels with some 225/45 Hankook Ventus V4ES
enjoy
some HP gains are coming...
EVO III 16G Rebuilt by Justin (jusmx141)
SBR install kit
this will be installed this week
Finally installed
16G vs T25
it wasn't easy to remove those turbo bolts
with intake on and SBR LICP
oil drain and feed
stock to the untrained eye
Keep this thread updated. It's your build thread and a record of what you've done. It also keeps people motivated on their own projects knowing that they too can make it happen even if things go bad at times.
Just putting that out there.
